newb with a question
Old May 26, 2005 | 08:12 PM
kruse'sws6ta's Avatar
Default newb with a question
Hello everybody. The problem I have is on swapping a cam. I installed the jpr cam tool and now when I push down on the pushrods they move down and then they will move up with the cam lobe. That means they are not locked in place right. Thanks for any help.
Old May 26, 2005 | 08:15 PM
Cal's Avatar
Cal
No, you're OK. It only holds them tight enough to keep them from dropping; it doesn't lock them in place.
Old May 26, 2005 | 08:18 PM
but if they can rest on the lobe what will keep them from going lower. Just really worried because I really dont want to have to pull the head
Old May 26, 2005 | 08:20 PM
blkZ28spt's Avatar
If you look at a cutaway/drawing you will see that those slots we stick dowel rods or the JPR tool in aren't directly under the middle of the lifter and they are shaped in a manner that allows a little movement. Have to see it, I cna't explain it. But you should be fine.
Old May 26, 2005 | 08:30 PM
Ok but if I pull the cam and one of the liferes fall you are gonna have to come and help me pull the head. Just kidding thanks for the help
