Fuel octane
for test n tune this week.
And this is about the 3rd time in the last year I've done this and every time
my car slows down.
Is this because I've not been tuned to high octane?
typically when people run higher octane they're way of tuning for it would be to "bump" the timing
when I was doing mustangs I believe the rule of thumb was for every point of timing advanced it was 1hp..
You could just run 93 octane u/l with your setup.
my car slows down.
Also, higher octane fuel is actually less explosive than a lower octane. The only reason its used in more powerful cars is because the gains from running higher compression or more boost far outweigh the comparitively small loss in combustability. No need to run anything but 93.
In fact, higher octane gas will require more ignition timing (advanced timing) because the fuel is harder to get light and burns slower.
Use the least octane that your engine will safely run on. This will depend upon application (stock motor will have different needs than a 14:1 race motor or a twin turbo'd monster with 25lbs of boost).
'Dreamin'
I got the car out at lunch and under WOT I'm get 3.5 deg
of KR and 26.7 deg timing.
Usually I get 0 KR at 29-29.5 deg timing.
I must have leaned it out too much at Test n tune.
I know my car is
do not run race gas unless you have lead resistant O2's, and even then they can still crap out on you if you use it too frequently.
