Bad oil sensor or jammed relief spring?
Old May 30, 2005 | 06:53 PM
Torqued's Avatar
Default Bad oil sensor or jammed relief spring?
This weekend I installed the LS6 valley cover and intake on my car. Car idles fine but now the oil pressure hovers midway between the red zone and the first tick. My guess is that the spring got jammed with some crap. I slowly took it up to 2000 rpms and the needle didn't budge. Wouldn't a bad sensor show a code?
Any suggestions?
Also, I have a dealer within 3 miles and a good speed shop within 6. If I keep the rpms down how risky is it to drive with the pressure that low?
Thanks in advance.
Old May 30, 2005 | 11:28 PM
Adrenaline_Z's Avatar
Which spring are you referring to? The oil pump pressure spring?
I believe if that spring sticks, the pressure will build. The spring regulates
the amount of pressure, by allowing the oil pressure to push against a valve.
The harder the spring, the higher the pressure.
Did you forget to install some oil restrictors on the top end of the motor?
I don't see the relation between the oil pump and valley pan otherwise?
Just a thought, I'm not familiar with the LSx oiling system.
Old May 31, 2005 | 12:19 AM
felton316's Avatar
It is possible that you cracked the oil sending unit while removing/installing the intake manifold.
Old May 31, 2005 | 05:23 AM
eallanboggs's Avatar
Pressure Relief Valve. Hmmm? Gee, I wonder if that might be used to relieve pressure NOT build pressure. I'll bet the pump builds up pressure and the pressure relief valve reduces pressure. Maybe that's why they call it the pressure RELIEF valve. Then again, maybe not
Old May 31, 2005 | 05:33 AM
PREDATOR-Z's Avatar
Coul be both or either so the cheapest is to replace the sensor, then go to the pump.
No I wouldn't drive that car. A tow is much cheaper than a block.
Old May 31, 2005 | 06:32 AM
Torqued's Avatar
Its definately the sending unit. Its sitting next to my keyboard now
Old May 31, 2005 | 07:34 AM
PREDATOR-Z's Avatar
Cool, glad this is solved.
Old May 31, 2005 | 07:51 AM
Let me guess that was directed toward me Eallan?
Read his question again about the spring, then read me post again, very carefully.
I'm basically stating it cannot be a stuck spring because the pressure would
build if the valve doesn't move to relieve pressure.
Here's a pic to show a valve and spring in a Gen 1 SB. Different design, same concept:
Old May 31, 2005 | 08:51 AM
GuitsBoy's Avatar
Originally Posted by Adrenaline_Z
I'm basically stating it cannot be a stuck spring because the pressure would build if the valve doesn't move to relieve pressure.
In LS1 applications, the pressure relief valve sticks open, not closed. This allows atleast some oil to bypass circulating through the motor.
Old May 31, 2005 | 09:34 AM
That's pretty much the same idea with the Gen 1. The valve will move
to reveal the bypass circuit (top photo).
Cool info, thanks Guitsboy.
Old May 31, 2005 | 07:33 PM
felton316's Avatar
Welcome to the club!
