Got my T-REX cam today?
Old Jun 2, 2005 | 09:07 PM
Randy WS6's Avatar
Question Got my T-REX cam today?
I've been waiting on this cam sence may 12th .Thunder raceing just got a new batch in . My quiston is the cam suppost to be 242/248-608/612-110 the T-Rex that I got is a 243.3/249.2-609/614-109.8 is that just the way they are ground.Will it much differance. And right now I have the EX-R Comp 232/236-595/600-110, My motor has a custom tune for the comp cam will there be much differance in the two cams when it comes to the tune,
Thanks,Randy
Old Jun 2, 2005 | 09:10 PM
BAIN's Avatar
The tune will have to be done again.
Old Jun 2, 2005 | 09:11 PM
ss rally red's Avatar
Cam specs will very by the 1000.00's no problem there,as far as the difference from your current cam cant say.
Old Jun 2, 2005 | 10:05 PM
sandking's Avatar
mine is 242.6/248.7-608/614-110.2. I think they all vary some. Tune again.
Old Jun 2, 2005 | 10:29 PM
Beast96Z's Avatar
Cams are never gunn be "exact". As for your tune, it'll prolly idle bad, but should still run ok once your going. It'll deffinatlly need to be redone to gain the max from the cam.
Old Jun 3, 2005 | 12:03 AM
Josh's Avatar
As the others have said, cam specs almost always vary from what's advertised.
I ran my T-ReX with the stock tune for several weeks and had surprisingly few problems, so you should be fine until you can get a tune specifically for the new cam.
Josh
Old Jun 3, 2005 | 12:50 AM
35th SS's Avatar
same here.just get it retune.
