TSP 233/239 vs TSP Torquer Rev2
Old Jan 4, 2007 | 12:24 AM
onebadrubi's Avatar
is the Tv2 cam going to "like" a 150 shot? I know that cam is a good all motor cam, will actually be going in a 6.0 but anyone have experience with that cam and say a 150 shot?
Sorry to hijack.
Old Jan 4, 2007 | 01:43 AM
PREDATOR-Z's Avatar
Sorry to hijack.
Yeah it likes 150, I'm running it in my 370cid Iron, 11.88 SCR
Old Jan 4, 2007 | 10:24 AM
onebadrubi's Avatar
I was just thinking nitrous might like a little more exhaust duration.
Old Jan 4, 2007 | 03:20 PM
camarokid94's Avatar
i DD my 233-239 cam no buckin or chugging. pulls like a train to 6800. sellin it now by the way on a 113
Old Jan 4, 2007 | 11:35 PM
chris93266's Avatar
i have a 233/239. it does not cold start well at all. i have an auto, so it's different than most of you. I know I have some tuning issues to solve. the 233/239 is actually a 232/238, so the difference is only lsa and 4 degrees of exhaust duration given both cams have same lobes. I'm not sure, but I think the torquer has lsk lobes? like i said, i'm not sure. can someone clarify? i hear lsk lobes are bad on valve springs and seats. anyway if you want dyno numbers, check the link in my sig. 233/239 .595 .603 & stg1 prc ls6 heads
Old Jan 5, 2007 | 12:41 AM
N4cer's Avatar
LSK lobes are theoretically easier on seats, and nobody has ran one long enough to prove that spring theory. So whoever you heard that from just plain lied. Nobody knows that for a fact yet.
Tv3: LSK/XE-R
Tv2: XE-R
Old Jan 5, 2007 | 09:11 AM
onebadrubi's Avatar
Are the LSK lobes any more radical or severe then XER?
Old Jan 5, 2007 | 09:54 AM
96LT4's Avatar
233/239 here with no issues after it warms up. Sometimes when cold it will want to die as it Idles really rough for 2 minutes. My 02 Z28 Put 400rwhp and 380rwtq through an A4, with only mods being 3600 edge converter, LT's,SLP lid,y-pipe w/cats, racetronix fp, svo #30 injectors,corsa cat-back, bryan herter tuned, and only 13k miles on the odometer.
Old Jan 5, 2007 | 11:05 AM
N4cer's Avatar
LSK has higher lift, but is easier on and off the seat. At least that's the theory I've heard.
Old Jan 5, 2007 | 11:07 AM
PREDATOR-Z's Avatar
That is a fact (not theory), you can compare the .006 lifts
Old Jan 5, 2007 | 11:42 AM
chris93266's Avatar
predator what are your referring to
Old Jan 5, 2007 | 12:54 PM
  #32
PREDATOR-Z's Avatar
That his comment is a fact not theory.
Old Jan 5, 2007 | 01:35 PM
  #33
chris93266's Avatar
thanks
Old Jan 5, 2007 | 07:08 PM
  #34
mcamarols1's Avatar
T2 here, i DD it, drove from el paso to cali, i got 25mpg w/ a fully loaded car, drives great, almost stock, mine idles at 850rpm il b getting a diffrent cam soon though, i was thinking PAT G's grind
Old Jan 6, 2007 | 06:33 PM
  #35
solobaric's Avatar
Sorry to hijack here! Just curious how driveability was with an A4 and STOCK convertor? Anyone have an opinion?
Old Jan 6, 2007 | 06:48 PM
  #36
crazylane's Avatar
Me to I would like to know this.
Old Jan 6, 2007 | 06:54 PM
  #37
Bad Blu Formula's Avatar
Anyone with an auto should consider a torque coverter before even thinking about getting a cam.
Old Jan 6, 2007 | 07:06 PM
  #38
crazylane's Avatar
Would it be okay to run the car without it for a few days, I am getting one, but it wont be until after I do my install.
Old Jan 6, 2007 | 07:39 PM
  #39
john563's Avatar
lets say your an A4 with a stall would you need more than 3:23 gears to run one of these cams?
Old Jan 6, 2007 | 08:29 PM
  #40
96LT4's Avatar
I have 3.23's with a 3600 stall, 233/239 and DD it anywhere!! oh and new times last night 11.80 flat all motor @ 117.983...
