cam experts step inside-->
Old Jun 5, 2005 | 02:57 PM
Gman2002Z06's Avatar
Yes, I agree with you...I only gained 18 rwhp going from headers from the stock manifolds...$1300 bucks for 18 rwhp is steep...
With a cam, I would still recommend doing headers...
And that is why I said that your first mod should be gears...That would be the best bang for the buck and still keep the criteria you stated that you are looking for...Stealthy and smooth idle...
Peace...Gman
Old Jun 5, 2005 | 03:10 PM
whitecamaross's Avatar
how much are gears?
Old Jun 5, 2005 | 03:14 PM
santiago's Avatar
Originally Posted by whitecamaross
i understand what you are saying about headers, but i have to find this article somewhere where u can see how good z06 exhaust manifolds are. i even saw that an x pipe swap on a z06 only gives you about 5rwhp. people are super angry at spending $300 dollars for 5rwhp and they will tell you that exhaust wise, the z06 has outstanding flowing capabilities as long as your internals remain the same. of course, if you are going to spray it is always good to get an off rd x pipe.
man......zo6 manifolds arent that great it sounds like your confused or something on how to mod that car.
step 1. vararam.
step 2. headers and mid pipe. stock catback is good.
step 3. cam
and there you go. easy as that
you got a corvette get used to boltons costing a bit more.
I had an ss so I know wuts goin on. I wish there were $350 longtubes for a vette but no there like 1k.
anyway good luck with with your z
Old Jun 5, 2005 | 03:17 PM
whitecamaross...Should be able to get a set of gears with install for about $900...And the guys that have had the gears done, say that the difference is between night and day...
Peace...Gman
Old Jun 5, 2005 | 03:31 PM
Turo's Avatar
I agree with everybody else, big cam really benefit from headers. Remember, the psople you see with small gains from exhaust probably had the stock cam, with a large cam the gains to be had from headers double.
But, you seem pretty determined to stick with the stock exhaust (I can't say I blame you, I know parts for corvettes can sometimes be quite a bit more $$$ than f-bodys), so just be sure of what you want to do, then pick a cam that is up to the task.
Old Jun 5, 2005 | 03:46 PM
hmmm..i would hate to have a lopey cam on a z06. it just rides so smooth and making it shake like a boat just isnt an option. damn, any other cams available? most of these companies now days are only making loepy cams and with aggressive ramps. i have seen mti's stealth, thunder racing cheater...any other suggestions?
Old Jun 5, 2005 | 07:17 PM
Patrick G's Avatar
LS1 Tech Administrator
Dude, I just gave you probably one of the most thought-out cams for a Z06 running stock exhaust there is: 220/228 .595/.598 (XE-R) 115LSA 114ICL. This cam will not have near as much lope as the TR 224/224, yet will outpower it with stock manifolds (because of better valve events designed specifically for running stock manifolds). Nobody seems to want to take the time to design you something custom. This cam will flat work. If -6 degrees of overlap is too much then I can redesign it, but expect to take a small hit in power.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old Jun 5, 2005 | 07:18 PM
what numbers do you think will be possible with it? will this cam out perform the cheatr cam?
Old Jun 5, 2005 | 07:44 PM
Patrick G's Avatar
This cam would slightly outperform the CheaTR only because it's a little beefier and it's more specifically designed for the Z06 exhaust (the CheaTR was designed around the stock C5 and stock F-Body exhaust manifolds). You will make peak power around 6300 rpm, carry power to 7,000 (with proper valve springs and pushrod length). Since the Z06 cam is already 20 rwhp better than the stock C5 cam, I wouldn't expect a 30-35 rwhp gain like the CheaTR has over the mild stock C5 and F-Body cams. You would probably see a nice increase in low end torque (10-20 lb ft) and probably 10-15 rwhp over the Z06 cam at its peak and probably 20-30 rwhp increase at 6500 rpm and above. Remember, the Z06 cam is pretty darn good to start off with.
Old Jun 5, 2005 | 09:42 PM
Visceral's Avatar
Originally Posted by Patrick G
This cam would slightly outperform the CheaTR only because it's a little beefier and it's more specifically designed for the Z06 exhaust (the CheaTR was designed around the stock C5 and .............Remember, the Z06 cam is pretty darn good to start off with.
Patrick came up with a good cam for your application there. I'd personally notch it down to 114 LSA.
Tony M asked a really important question that you never answered... was your original TR 224 cam on a 112 or 114? I'd agree (imho) that too much lope doesnt belong in a Z06. But going too far with the LSA (116+) is going to lose you alot of midrange with the larger durations.
If you dont want to do headers, fine. No big deal. Headers/Cam are the biggest team players here, especially with your 243 heads, so it would be a shame, but by all means you should do what makes sense for you.
Try Patrick G's cam by calling up Geoff at Thunder Racing and asking him to build a cam around 220/228 on a 114 (or 115) for you. He'll plot the IVC and do it right.
Chris
Old Jun 5, 2005 | 10:34 PM
Patrick G's Avatar
Chris
Thanks for the props Chris. I thought about going narrower on the LSA, but I chose the 115LSA for a couple of reasons. The stock LS6 cam has -24 degrees of overlap. The TR 224/224 112LSA cam has 0 degrees of overlap and the TR 224/224 114LSA cam has -4 degrees of overlap. Worst case scenario, if he originally had the 114LSA cam and thought it was too much, then I'd want to back off a little from that, hence the 115LSA cam with -6 degrees of overlap. Considering the nice gains down low Jason99T/A had with the 117LSA CheaTR cam on a cam-only swap, I'd look for some really nice low rpm torque gains, even at the wider 115LSA. That's still better than the 117.5LSA of the stock LS6 cam.
Second reason (the biggest of all). I chose the valve events the Z06 needed and the LSA was what it was. I really wanted the intake to close at 44 degrees ABDC (for best overall power) and the exhaust to open at 50 degrees BBDC (to work best with Z06 manifolds). For this to happen with the 220/228 durations, I came up with exactly 115LSA. If I narrowed the LSA to 114 (and keep the same ICL), the exhaust opens 2 degrees later and that would not be good when running manifolds. You need a little earlier opening when running logs...even good logs like the Z06 has.
__________________
