Need Help. Those with Double Rollers
Old Jun 5, 2005 | 12:13 PM
'02 SLP#686's Avatar
Default Need Help. Those with Double Rollers
I am swapping over parts to my new LS6, I used a rollmaster double roller and now I am installing my oil pump and it is touching the chain. Am I supposed to be using shims behind the oil pump?
I really need to get this done ASAP. Any help would be GREATLY appreciated.
Old Jun 5, 2005 | 12:16 PM
nostyta's Avatar
If it is touching the oil pump it will have to be shimed, you should have recieved some with your double roller setup.
Old Jun 5, 2005 | 12:33 PM
The chain was on the motor with cam installed when I bought it. I need to find some shims... DAMNIT
Thanks man.
Old Jun 5, 2005 | 02:24 PM
HavATampa's Avatar
Do a search. There is a post from last year with specs and drawings of the 2 shims that can you have made. Good luck on finding the shims without buying another pump. Don't know if it's possible or not.
Old Jun 5, 2005 | 02:32 PM
PREDATOR-Z's Avatar
https://ls1tech.com/forums/showthrea...ght=pump+shims
If I remember correctly CyphurTraq has a schematic.
Old Jun 5, 2005 | 03:04 PM
HavATampa's Avatar
Yeah, that's the link I was thinking of. For some, reason the drawings are missing though from Cyphur's post.
