Gasket removal
Old Jun 5, 2005 | 12:51 PM
1999TransamWs6's Avatar
Default Gasket removal
I was just wondering if it would be a good idea to give the surface of the block (were the heads mate) i rub with some emery cloth (very fine sand paper) Also will very fine nicks harm anything?
Old Jun 5, 2005 | 01:04 PM
conan's Avatar
I have heard or people useing fine grit sand paper and wd40. The emery cloth might be to abrasive.
Old Jun 5, 2005 | 01:08 PM
PREDATOR-Z's Avatar
Depends which gaskets you are using. Cometics need a clean staight surface and GM graphites are more forgiving.
At worst use a 600>800 wet sanding but make sure you do not spend too much time in one area.
I use plastic craper and brake cleaner with tons of coarser cloth (old jeans Denim), all of that while holding a shop vac tube close to scraping area, to suck everything in order not to drop debris in water holes.
Old Jun 5, 2005 | 01:19 PM
Yea im going to be using cometic gaskets
Old Jun 5, 2005 | 01:47 PM
PREDATOR-Z's Avatar
Then do not make any scratches, or they will leak.
Old Jun 5, 2005 | 06:20 PM
I finished removing all of the gasket material it looks brand new. I first scrapped it off with a razor blade very gently and made very small minor nicks that are not noticible to touch and then sprayed wd-40 on the deck and sanded it with some very fine sand paper. it looks very smooth and feels like glass so ni think i got it done.
Old Jun 5, 2005 | 06:36 PM
383LQ4SS's Avatar
Scotchbrite and MEK. Thats how i cleaned my head surface and block each time. It will leave it residue free and VERY clean. The scratches the Scotchbrite leave are more like polishing. I have not had a leak with my cometics yet since doing it this way.
MEK is methyl ethyl ketone and can be purchased at Home Depot. Just wear gloves when using.
