New big cam, couple ?'s
Old Jun 5, 2005 | 09:37 PM
foxbody's Avatar
Default New big cam, couple ?'s
What oil pressure should I see after the motor is warm with an LS6 ported oil pump? And at what RPM? Also, what is the difference b/w the LS1 oil pump and the LS6 oil pump? Is it only the pressure spring? If I port the stock LS1 pump and swap out the springs from the LS6, would it be just as good as the LS6 oil pump?
