engine knock
Old Jun 7, 2005 | 12:53 PM
ozzykicks2002's Avatar
Default engine knock
You know how a engine sounds when its low on oil? my engine will make that sound, even though I have 7 quarts in it I have a 2001 WS6. And when it warms up it will stop. should I worry about this?
Old Jun 7, 2005 | 12:57 PM
conan's Avatar
7qt's is too much oil ls1's hold about 5.5qt's. Is the sound comming from the valve train or bottom end? Could be a lifter or a spun bearing.
Old Jun 7, 2005 | 02:04 PM
~JOSHUA's Avatar
7 quarts will be harmful for your engine... check your dipstick and correct the level!
If you have a sound kind of like a marble or marbles starting about 20 seconds after a cold start and also after a warm restart, then you most likely have piston slap which isn't harmful.
correct the oil level now!
Old Jun 7, 2005 | 02:05 PM
patSS/00's Avatar
Sounds like the infamous "cold piston slap". Do a search, you'll find lots of posts. Most LS1's seem to have this feature. I think it's at least partly due to the block expanding faster than the pistons.
Old Jun 7, 2005 | 02:38 PM
~JOSHUA's Avatar
Actually, piston slap has more to do with the metal content of the pistons and the barrel shape cast that figures in the expansion rates. Its seems a lot of the LS1's are on the high side of tolerance as far as piston/bore clearance.
Old Jun 7, 2005 | 06:48 PM
lol I read here on the forum that people were recommending 7 quarts because of the fact that the number 6 bearing i think will spin. lol I will correct right now
Old Jun 8, 2005 | 04:27 PM
ls1charged's Avatar
7 quarts is a little to much your supposed to put a little more than five
