Oil pressure low at idle
Old Jun 8, 2005 | 01:23 AM
Don's01z28's Avatar
Default Oil pressure low at idle
What's up guys? I have a 01 a4 and when i start it up the oil pressure is low. When i get up to crusing speeds the pressure is perfect. Also, i notice a whine when i first start it up. It stops after a few minutes. Is the problem my oil pump? The motor has 76,000 miles on it. Any ideas? Thanks in advance.
Old Jun 8, 2005 | 04:57 AM
1FASTLS's Avatar
Default oil pressure
How low is low, mine stays around 39psi after warming up not sure about whine when you first start check water pump.
Old Jun 8, 2005 | 09:43 PM
Don's01z28's Avatar
about 30psi
Old Jun 8, 2005 | 10:27 PM
conan's Avatar
Originally Posted by Don's01z28
about 30psi
Cold start is 30psi? The whine is your air pump.
Old Jun 19, 2005 | 03:28 AM
Don's01z28's Avatar
thanks conan
Old Jun 19, 2005 | 04:30 AM
PREDATOR-Z's Avatar
All is normal, average is 7>10 psi / 1000rpm (that depends also on weight of oil used, and if ported or not)
