Is 5.3 Iron block same as LS1?
Old Jun 10, 2005 | 03:06 PM
HydroStream6's Avatar
Default Is 5.3 Iron block same as LS1?
I recently cracked my LS1 block. I can do an LS6 upgrade or go iron. My question is, can a 5.3 iron block be bored to basically the same as a 6.0, then use all of my stock accessories, heads, etc.
Thanks
-Adam
Old Jun 10, 2005 | 04:01 PM
zamboxl's Avatar
a 5.3 iron block cannot be bored to 6.0 but u could always use a bore strocke combo and get ur self there.
Old Jun 10, 2005 | 04:50 PM
69firebird's Avatar
5.3 can be bored to a 3.905-3.908 very easily. It would make for a nice strong motor.
Old Jun 10, 2005 | 04:58 PM
Do all accessory holes, etc, line up correctly for an 04 LS1? I imagine it would...
Old Jun 10, 2005 | 05:27 PM
Grimes's Avatar
Yeah, you can get the 5.3 to the 5.7 bore (3.893), but not to the 6.0 bore (4.000).
Accessory mounts should line up, but if you have some bad luck, drilling and tapping an accessory hole wouldn't be that difficult
Old Jun 10, 2005 | 07:41 PM
smask04C5's Avatar
all the accessory holes will be identical 5.3 can be bored safely to 3.905
Old Jun 10, 2005 | 08:02 PM
Hmm, interesting. This will end up being a 9:1 motor for my turbo. Would like to get a 6.0 but I might be able to get a deal on a new 5.3
Thanks for the replies.
