Which pushrods?
Old Jun 11, 2005 | 08:29 PM
byrontaylor's Avatar
Default Which pushrods?
I have a .538/.538, 228/228, 114 lsa cam with other mods in sig. I gout trick flow 7.400 pushrods and I am installing it all tomorrow, cleaning parts now. My question is a little late I know but I got to thinking about the pushrods. When do you use the 7.350, or the 7.450 or just stock replacements? What is the difference it makes on the cam?
Old Jun 11, 2005 | 08:38 PM
ninobrn99's Avatar
the smaller ones are for when you get the heads done. Im running a similar cam. the f10 on a 114. Ive got PRC dual springs and futral hardened pushrods. I think i should've stuck with the stockers just incase i miss a shift or over rev.
Old Jun 11, 2005 | 08:48 PM
I see, they are not hard to change out though. What effects does it have on the cam if any, surely a longer pushrod would do something to the cam or am I just thinking wrong?
Old Jun 11, 2005 | 10:02 PM
bigdsz's Avatar
The 7.4's are longer than stock to compensate for the smaller base circle on the cam lobes of the new bigger cam, so that you can fit the lobes through the cam bearing holes. The 7.350's and smaller than OEM PR is for heads that have been milled or heads that have valves with .050 or .100 longer valve stems. If you don't use the shorter PR then you will screw up the valve train geometry. Like where therocker arm actually touches on the top of the valve. That is why you put black magic marker on the top of the valve and then see where the marker wears off.
Old Jun 11, 2005 | 10:18 PM
I see, I guess I had better let a mechanic handle this part lol.
Old Jun 12, 2005 | 03:07 AM
TNormZ28's Avatar
Uh, 7.4 is stock length. Use shorter prs if your heads are milled if you want your motor to start an maintain compression. I would have used stock pushrods with this cam.
Old Jun 12, 2005 | 07:12 AM
PREDATOR-Z's Avatar
Stock LS1 (mine) were 7.38
Aftermarket stock is 7.40
If your heads are unmilled, then use 7.40's unless it is an LS6 cam, the it is 7.425's
Old Jun 12, 2005 | 11:30 AM
Blue Falcon's Avatar
Would the 7.400"'s be fine on a 224/224 .581/.581 112 with TEA 5.3's milled .010"?
 Michael S. Palmer
Old Jun 12, 2005 | 11:33 AM
PREDATOR-Z's Avatar
Yes they will be perfect.
Old Jun 12, 2005 | 11:52 AM
thanks
Old Jun 12, 2005 | 12:37 PM
Easy enough...thanks guys.
Predator-Z, you're gonna get tired of answering my stupid ?'s
Old Jun 12, 2005 | 12:42 PM
PREDATOR-Z's Avatar
Nah! Keeps the memory fresh
Old Jun 12, 2005 | 12:50 PM
lol thanks alot though
Old Jun 12, 2005 | 01:06 PM
ninobrn99's Avatar
dude, you dont need a mechanic to change pushrods. take of the coilpacks. valve cover, rockerarms, then pull and replace the PR's and reassemble. Just that easy.
Old Jun 12, 2005 | 01:10 PM
I was jk...I am doing all the mods in sig start tomorrow morning when I get off of work. Anyone in Arkansas or close can help if they want. 870-413-9304 is phone #.
