Milling an LS6 Intake to fit...?
The heads are milled (not sure if they angled or not or both) .040.
Question...if my intake is not fastened to the heads perfectly due the heads being milled this much could this be my issue with the lean condition on 1 bank of cylinders? I can't find a vacuum leak anywhere, sprayed carb cleaner all around the intake and ZERO happens.
Can this be the issue and if so, can I mill the intake to match the heads some how to get rid of this problem?
