Max RPM?
Old Jun 14, 2005 | 05:50 PM
1999TransamWs6's Avatar
Default Max RPM?
I was wondering how high a stock bottom end was able to rev to with only ARP connecting rod bolts and everything else stock?
Old Jun 14, 2005 | 05:57 PM
conan's Avatar
A cam should determine your max rpms. Your power will drop way off a certain rpm with differant cams. My tr224 fell on its face at 6900rpm so I had the rev limiter set at 6800rpm. I have read of some spinning 7000+ W/ the arp rod bolts, But if your not making power up there no need to spin it that high.
Old Jun 15, 2005 | 10:15 PM
My cam makes power up to 7000 will the motor rev up that high?
Old Jun 15, 2005 | 10:41 PM
luv2spd's Avatar
Sure it will. Keep in mind that while the ARP rod bolts will help, you're still severely shortening the life of your shortblock.
Old Jun 15, 2005 | 11:20 PM
'02 SLP#686's Avatar
What he said
Old Jun 15, 2005 | 11:36 PM
Dan_the_C5_Man's Avatar
I agree..
Old Jun 16, 2005 | 12:12 AM
RTCamaroSS's Avatar
I spin my trex to 7000... fuel cut set at 7200 i beleive... no arp rod bolts... im on borrowed time im sure.
