Low Dyno Numbers with 423 stroker
That cam is WAY WAY too small even for a truck. You have a TON of horsepower with a cam change. The cam is peaking around 5000rpm LOL!
Also did ARE port the heads? What truck is this motor in? They have heavy drivetrains as well.
The trq curve seems on track so I would relate this to cam also. Look at the cubes, that duration is waaaaaay to small to feed this ape.
You got yourself a nice tow truck now (not funny, I know, but couldn't resist)
Who on earth picked that cam for that motor? I'm going with a 248/252 113 lsa, maybe you should just go to that too.
Looks like he locked the converter up on that dyno run.. Now it looks like its about where it should be with that teenyweeny camshaft. I'll bet money that with a custom 240+ camshaft that it would pick up a good 50rwhp. Cause all you've got right now is a stock like big cube motor with no air getting in or out.
Until then I'm just going to spray the hell out of it.
Ok, seriously though, cam, springs, and make sure the tuner tunes the TC in right as well as AFR. Good luck on it and bet you will soon be pumping out mad power.
