Kinda odd recommendations from Futral?
Thanks
I envy people that live within 100 miles from Futral and Allen's expertise.
Thank God for you I don't, you would probably put a restraining order on me LOL
Your help would be so appreciated. Thanks Candy.
Mark
You have a sister? Cause I need someone like you to help around my shop!
Bret
Sorry, I dont have a sister, Im sure we could clone one up pretty soon..
I've inqired by e-mail as to the (FM9 fitting PRC 5.3L 62cc (2.04 int/1.585 exh) with GM .054 compressed gasket, .007 piston out of hole) and after a week the answer was " You'll just have to check it out".
To me that didn't sell me the cam for sure. i do not want to flycut so the answer before purchase is imperative. my thought was, "fewwww, that is a lot of help
)Perhaps could you help Candy??
I've talked to Futral staff a few times and each time learned more about the variables involved with PtoV. I didn't realize how much the valve job alone could impact clearence issues.
We're pushing the envelope trying to make more power out of our LSx motors. The only for certain answer is that stock heads with stock valves will clear the pistons when using the stock cam and valave train.
Don't mean to be be flippent, you've been helpful to me and I can apreicaite your being out of the country. I live in a real rural area and finding parts can be a PITA
I'm still using your compression calculator playing with all the different possibilities.Citing the fact that Candy is married and so am I...I'll withhold any comments about talking to a sweet southern accented young lady with more knowledge about motors than I do being any kind of a turn on
Last I looked cometic didn't offer a .042 gasket.
They had .045 and a .040
When using a .040 gasket you will get the 11.1 CR your after with no milling of the heads. With no milling and the .045 gasket you get just over 10.85:1 CR.
I would mill the heads about 6-8 thousands and use the .045 gasket for the compression you seek, or dont mill at all and use the .040 gasket.
As far as clearence goes.
I would flycut and be safe. If I was a beting man I would bet it dosen't fit without flycuting.
Just my oponion. The valve job will be a big factor.
Bruce
At least that sounds good for now...I'll talk to Allan when I get the cc numbers in and see what he suggests.
I'm definitely going to have to measure up first if need be I might have to buy the Cometics or just settle for 10.8:1 or so????
Oh well,....I hope the sales fallow
Candy,
Thanks for your time today!
Yep it was pretty hot today, dont know if its the weather or talking about cars all day
Thanks
Candy
) have in stock.Also, when my builder go tthe cam package he unpacked everything expecting to debur the springs and retainers, but to his surprise everything had been hand cleaned and was ready to go. He told me everything I bought looked top quality.
Thanks again and I'll try calling tomorrow when I get a chance.
I agree SSheets,
What meant by "ballpark figure" is will it fit without flycutting. I cannot flycut here so if cam is borderline, then suggest a close alternative that will fit.
All cams should be degreed anyways so it will be "checked" anyways.
But I do not want to get the FM9, only to find out I need to flycut and then I have to ship back (one way shipping cost me ($150+))
Now FM7 is too small and within my actual cam range.
Perhaps a FM8 1/2
