Valve Train Help needed......
The stock lobe lift of a stock 2002 cam is .281 and the new cam we put in has a lobe lift of .346 intake and .339 exhaust so using the intake as the example this means that the base circle of the new cam is 0.065 smaller and would require a 0.065 longer pushrod…the stock PR’s are 7.38” in length so 7.38 + 0.065 = 7.445 the closest PR to this length is 7.425…..in addition to the extra length needed by smaller base circle cam we put a thicker head gasket on which is .052….which is 0.012 thicker than the graphite head gaskets that were on there…..this puts us needing a 7.457 PR with 0 lash…..unless I’m crazy a 7.425 pushrod would put us back pretty close to the stock geometry with the preload really close to the stock settings……or would a 7.450 be a better choice....
I've been pulling my hair out trying to figure out which PR's I need....Thanks for the help....
So that puts you at 7.446 correct intake and 7.438 exhaust.
So the 7.425 are off shelf length.
Or you have custom length ones made with the above correct int/exhaust length.
BTW that intake diference at the cam is huge.
So 7.425 should be close to the right length....this is what I was hoping....
Thanks guys.....
