afr 225s and a big cam...flycutting?
Also, what do you do about the difference in the bore size between a stock ls1 and the 4.000 on the 402?
As far as the bore size differences, ANY 225 headed combination must run a 4.125 minimum bore gasket anyway so technically both combinations would take the same head gasket.
Tony M.
