Got an oil analysis: lead content high?
.Anyway, I received the report from Blackstone and they noted that lead content was high (20ppm where their average is 7ppm). They said that this is abnormal but not catastrophic. Normally lead indicates bearings but supposedly it's not high enough for that. I told them that the car sees track duty and they said that the lead is probably from leaded gas or additives. I don't use either and I have changed my oil several times since I bought the car so I don't think it's carried over from the P.O. I got to looking at the report and there are a few catagories that are slightly higher than the average and it got me a little worried. As near stock as I am right now, it doesn't concern me, but I am worried about the future of this engine as I mod. However, they said my oil was consistent with what they have seen of samples with 4100 miles on them but mine was 6800. Then they suggested I go to 7500 next time. So they thought my sample looked good, but it had high enough lead content for them to say something. There was no fuel or water found and insolubles were low showing good oil filtration, they said. They also said they'd "keep an eye on the lead". Here's a few of the other slightly high materials:
Material Mine Average
Iron 18 14
Molybdenum 94 54
Calcium 3091 2265
Phosphorous 814 751
Zinc 1079 894
*in parts per million (ppm)
Has anyone had any experience reading these analyses? Could stock plugs or high lead content in the gas I buy cause the slightly high count? Are these few ppm insignificant in the big picture and I'm just freaking over nothing?
Thanks
Here's my results. Some quick bits of info. Oil was in car for 11 days, covered 7,656 miles with aprox 150mile from road course's, 3 1/4mile passes. Car had 3 big misshifts on my part aleast 6500 rpms and had alot of sustained high rpm racing on the track's.
Car was Raced in the One Lap Of America.
The mobil 1 mileage is less, drivng and racing conditions about the same. I thought I would put these together.
The last Kendall uoa was in car for a Drivng school and trip only. race track mileage was 200 miles in 2 days. 5 20 min sessions on sat and 3 on sunday.
kendall 5/40/Mobil 1 5-30/kendall 5-40
Mileage 45868 35700 37465
Oil 7656 5000 1200
Iron 19 28 14
Chromium 1 1 0
Nickel 0 0 0
Alum 3 6 2
Copper 14 21 6
Lead 1 2 0
Tin 3 2 1
Cadmium 0 0 0
Silver 0 0 0
Titanium 0 0 0
Vanadium 0 0 0
Silicon 5 8 4
sodium 14 6 5
Potassium 17 1 2
Moly 4 89 13
Antimony 0 1 0
Manganese 0 0 3
Lithium 0 0 0
Boron 10 184 30
Magnesium 920 34 788
Calcium 1584 3334 1631
Barium 0 0 0
Phosphorus 909 778 724
Zinc 1069 1017 940
Fuel% 2.5 .5 .5
Soot% <.1 .1 .1
h20% <.1 .1 .1
Vis 100cs 13.8 10.1 13.0
TBN 5.17 5.74 7.07
Oxid 10 24 8
Nita 24 25 10
The next time you have an oil analysis done by Blackstone Labs, I would suggest that you tell them you want the Dyson analysis. Terry Dyson will breakdown your report element by element and tell you what you need to do to reduce your wear numbers.
