ls1 500 hp problem
i just bought and had installed an ls1 with a 551 intake and exhaust and 228 intake and exhaust degree cam, forged pistons, ported heads and throttle body. the problem is that it seems that cylinder 1 5 and 6 are misfiring....what can cause this? i checked all the wires and they are fine as far as the tester shows. maybe the headers getting them too hot? well i drove to work this morning and the service engine light turned off so it means they are all firing as they should, so what the hell is going on? let me know what you guys think
thanks,
sandro
also if anyone knows any good mechanics in the los angeles area that can deal with a motor like this please let me know where and how i can contact him
thanks,
sandro
it was run through a scanning tool and it showed those three cylinders misfiring pretty badly. then this morning the service engine light went off which means those codes cleared which should mean they are not misfiring anymore right>? the motor is a 500 hp motor at the flywheel.
maybe a bad camshaft positioning sensor? not sure what it does but could it keep the valves from opening correctly? any advise is appreciated, this is my first motor and i dont know toooo much about internal engine stuff....
thanks,
sandro
thanks,
sandro
It's normal for misfire codes to be set with a bigger than stock cam. You can get it adjusted to be less sensitive with a tuner. How's the car running? Have you pulled the plugs to make sure they are ok?
well since then the sucker has been a little shaky and it didnt rip the tires off the car as it did the first time i stepped on it. it sent me sideways and now it just doesnt feel as strong you know? i dont know what to make of it but you can tell its misfiring.....gonna go home and see how it runs, let me know what you think and ill get back to you tonight or tomorrow.
thanks,
sandro
thanks,
sandro
