6.0L heads
Problem is the chambers are huge and need to be machined "Welded chambers" to bring the size down without hurting flow.
Good head to have for stroker/& FI applications, then just CNC+bigger valve & job + hand finish will yield good results.
4.8/5.3 L ported are the most cost effective heads to run with good results.
