Newbie question... What size cam?
Originally Posted by greatskiiiier
for example, say an XE-R lobe cam has .590 lift, the TR224 cam will put out the same HP and ET gains, even though it only has a lift of .560 (with the same duration)
So you are saying that an XE-R lobed cam with .590 lift and otherwise equal specs to a TR224 (which has only .563 lift) would be weaker and slower than the TR224?
Where have you heard this?
Originally Posted by blkZ28spt
XE-R is a an aggressive lobe. Even with slower ramp rates two otherwise identical cams should produce roughly the same peak power output.
