Material used in stock LS6 springs?
Old Jun 29, 2005 | 10:06 AM
gmblack3's Avatar
Default Material used in stock LS6 springs?
I know its something that a magnet will hold, but is it mostly iron or what?
thanks!
Old Jun 29, 2005 | 10:35 AM
oange ss's Avatar
spring steel
Old Jun 29, 2005 | 10:58 AM
Cstraub's Avatar
Vanadium Chrome Silicon Steel
Old Jun 29, 2005 | 10:59 AM
777's Avatar
777
Old Jun 29, 2005 | 11:02 AM
gmblack3's Avatar
Thanks Everyone!
Old Jun 29, 2005 | 12:52 PM
Old SStroker's Avatar
thanks!
Actually you are more correct than you realize. All steel, even valve spring steel only has a few % of the alloying elements like Chromium, Vanadium, Carbon, Silicon, Sulphur. etc. The balance is iron! Of course it's not anything like Cast iron you'll find in blocks, some heads, etc.
As important as the alloy is the purity of the steel. Any impurities like "dirt" that get trapped inside the wire cause stress risers which can lead to failure with more time on the engine. OEM springs and lifts are chosen to not stress the springs as highly as we do with aftermarker cams.
