need suggestions. changing a block.
Old Jun 30, 2005 | 01:37 AM
ALPHA Q's Avatar
Default need suggestions. changing a block.
My motor (of a 98 TA 39,000 mi) got hydrolocked with probably 1 or 2 bent rods and the block is cracked so I'm going to get a used block and used rods as well. I'm going to transfer whatever I can from the cracked block. The car is basically stock except for a lid and a catback.
does it have to be machined and balanced before I put in?
WHAT IS NECESSARY TO DO THE SWAP SAFELY?
accesories, recommendations, precautions, etc.
also a 03 z06 cam is going to be installed during this process, what else does it have to be changed when installing this cam?
I really apreciate the help guys! Thanks !!!!
Old Jun 30, 2005 | 07:03 AM
conan's Avatar
Make sure the decks are straight on the block, get the rotating assembly ballanced, cylinder hone, line hone, new rings, and new cam bearing would be a good idea too. On the cam, get some ls6 springs and make sure you didn't bend your push rods.
Old Jul 2, 2005 | 01:36 AM
ALPHA Q's Avatar
thanks, I apreciate the help man!
also,
what kind of ARP bolts are recommended to use?
what are the common things that happen when a motor gets hydrolocked?
I'm not very familiar with the LS1 internals so I'm sorry if this are dumb questions!!
Old Jul 4, 2005 | 03:40 PM
ALPHA Q's Avatar
anyone ?
