MS3 and nitrous??
if you go with a dry kit, then add bigger injectors to the list - 42#er's should definitely be good
then throw a 150 shot at it
save up some money for a new rear cause it isn't going to last long
The main reason M6's are hard on the rear is the sudden jolting nature of dumping the clutch from high rpm and slamming it into second gear.
