Tstat
Old Jul 9, 2005 | 11:34 AM
doublestack's Avatar
Default Tstat
what else would need to be done when swapping to a 160 degree tstat. any tuning needed?? Thanks for any info in advance.
Old Jul 9, 2005 | 11:51 AM
Nasty N8's Avatar
You can run the T-stat with no tuning it will help out. Works even better when you start building HP and then have it tuned for the fans.
NAte
Old Jul 9, 2005 | 01:08 PM
1FST99Z's Avatar
yeah, no tuning needed. just gonna make your car run cooler. better in the long run
Old Jul 9, 2005 | 04:14 PM
slt200mph's Avatar
The 160 degree thermo will open at 160 degrees...that does not mean it will run at 160...you will have to get an edit done to have your fans come sooner for it to really do you much good in keeping the temp lower
Old Jul 9, 2005 | 04:18 PM
blkZ28spt's Avatar
IMO you are better off leaving the stock T-stat in there and either getting a manual fan switch or having them set to come on sooner.
Old Jul 9, 2005 | 11:57 PM
TJ's Avatar
TJ
wont the lower temps run more rich(without tuning) ?
