No idea What You Are On About !
Cheers big ears
Rob
and god bless all u britsedit::: o and i guess u got my point but just to be safe by lsx i meant any ls based angine like ls1, ls6, ls2, and i guess ls7 but not to sure about that one since it's not out yet lol.
Unfortunately I am a bit of a div when it comes to engines so simpler the better
!Another div question. What is the deal with the cam range quoting say for the RM13 1600 - 6800 rev range and the fact it can idle at far lower ?
Cheers
Rob
Cheers
Rob
The factory road racing cams have reasonable lift with a long duration.
I would not listen to "most" of the guys here, they have ZERO road racing experience, zero experience road racing an LS 427 and about 1 in 50 has a 427. The C5R (427) guys generally shift at 6,000-6,500. This why this combination is reliable, just don't need to shift any higher. The Caddy is running a destroked 331 and is shifting in the mid-7,000 range. They had all kinds of problems finishing last year.
On a two minute course, you "might" see a 0.1-0.5 second difference between shifting 6k of 6.5k depending on the straights. If your racing professionally you need every tenth and will be rebuilding your motor on a regular basis (and have five spares).
depends on your budget for mods.
You have raced at The Ring???
That is a dream of mine.........someday before I'm 50 I will do laps at that monster! The Best V8 Stories One Small Block at Time
Cheers
Rob
I've got a div question too...... What's a dive?
And on a side note, I'm staying up to respect your 2 minutes of silence. I can't tell you how much we appreciate Great Britton.
edit::: o and when did he say this was going to be a track only car. I am not talking out of track experience i am talking out of daily driving real world expirience on 1.7 rockers u can run a larger more agresive cam, with better idle than a smaller cam on 1.8 rockers damn go drive around in the real world ok before u start trashing other plp on here. o and did i mention 1.8 WILL LIMIT UR AFTERMARKET CAM CHOISE ON A 346 BEACAUSE OF THe AGRESIVE AFTER MARKET CAM RAMP RATE!!!! go read before u trash. o and u did read the part where he said the car was gona be daily driven right?
Quaint English term = Divvy - Shortened to Div = Thick Person
