Refreshing an engine ?
Old Jul 12, 2005 | 04:06 PM
Spellbound's Avatar
Default Refreshing an engine ?
The engine has ARP hardware, rod bolts, main studs. This may be a dumb question but, can you reuse the rod bolts? Studs? If the bores are good, can You reuse the Pistons? What type of rings and bearings should I get? The engine was a track only iron block 408, with forged internals and about 392 passes on it.
TIA
