double roller timing chain
Old Jul 13, 2005 | 12:44 PM
LS198TA's Avatar
Default double roller timing chain
i have a double roller timing chain from rollmaster, does anyone know how much to machine off on a asp pulley so the belt will line up?
Old Jul 13, 2005 | 11:51 PM
nostyta's Avatar
Should be 3mm.
Old Jul 14, 2005 | 08:23 AM
LS198TA's Avatar
i just did a search found out if you buy the SFI approved pulleys they already come machined for double roller timing chains
Old Jul 14, 2005 | 06:06 PM
blkZ28spt's Avatar
Unless it's an older pulley you should be fine.
Old Jul 24, 2005 | 06:25 PM
SideStep's Avatar
How would you know if you had an old pulley???
