Help!!!!
Old Jul 16, 2005 | 10:32 AM
Trojack's Avatar
Default Help!!!!
Just did heads/cam swap now the engine will not fire.
Any suggestions?
Old Jul 16, 2005 | 10:33 AM
Trojack's Avatar
sorry the engine turns over fine, there is fuel, it just wont fire. The engine just spins from the starter.
Old Jul 16, 2005 | 10:48 AM
slt200mph's Avatar
Did you plug in your coil packs??
Old Jul 16, 2005 | 10:53 AM
NOSjohn's Avatar
Restricted User
Check all your wiring...especially grounds. Pull a plug, ground it to something and see if there is spark.
Old Jul 16, 2005 | 10:54 AM
Trojack's Avatar
yes the coil packs are plugged in and i show that they are sparking.
Old Jul 16, 2005 | 11:04 AM
Demon SS's Avatar
are you positive there is fuel? check all of the ground straps that are attached to the back of the heads one of them may be loose/not connected and causing an issue.
