compression calculation
Old Jul 17, 2005 | 06:54 PM
smask04C5's Avatar
Default compression calculation
getting ready to install afr 62cc heads with cometic .040 gaskets. pistons out of hole .007. i am planning on using the crane cam i have now, 216/224 115 lsa with .590 lift on 1.8 crane rockers. intake closes @ 38* ABDC. will i be ok with scr and dcr with this combination?
Old Jul 18, 2005 | 06:40 AM
smask04C5's Avatar
ttt, anyone?
Old Jul 18, 2005 | 04:36 PM
Phil'sC5vette's Avatar
I see Texas speed has the .40 gaskets and Thunder racing as the .45. I wonder if there are two gaskets or someone is wrong.
Im going with the 63cc, .40 gasket, with the TR224. I should be just under 11:1
Old Jul 18, 2005 | 05:11 PM
smask04C5's Avatar
calculated scr and dcr using an intake closing 73*ABDC, with a 62 cc chamber and a .040 cometic, i get 11.3:1 and 8.4:1 respectively. cometic carries a number of thicknesses, just thought .040 would be best. don't really need to twist above 6K with my setup. Thanks phil
