Old May 18, 2016, 06:15 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine Guides
Print Wikipost
How To Remove the Engine From the Bottom
Old Jul 26, 2005 | 11:38 AM
2000_LS1's Avatar
Were the instructions above what you followed? If not what did you do differently?
Old Jul 26, 2005 | 09:10 PM
Mr. Luos's Avatar
Basicly.
I tore down a little more than the instructions said to though. I had a buyer for the cam that was in it, so I wanted to get that out and sold. That was 2 weeks before actually pulling the motor, so you can kinda understand why I did that.
The only thing I had problems with was the clutch line on the tranny....it didn't want to come off, and the brake lines.
Old Jul 26, 2005 | 09:50 PM
2000_LS1's Avatar
OKay good, I was hoping I didn't miss a step or anything. Thanks for the confirmation.
Old Aug 4, 2005 | 06:19 PM
Hawkeye's Avatar
what did you guys attach the engine hoist to? Strut towers? rad support?
Old Aug 4, 2005 | 07:20 PM
bumpin_records's Avatar
i was about to ask the same question
Old Aug 5, 2005 | 02:46 PM
2000_LS1's Avatar
Most do it to the radiator supports I believe, Although I don't see anthing wrong with the strut towers.
Old Aug 5, 2005 | 04:15 PM
Mr. Luos's Avatar
I used the strut tower brace.
Although, the hoist came REAL close to nailing the front clip, so I think when I slide the motor back in, we will use the radiator support.
Old Aug 5, 2005 | 11:05 PM
gearheads78's Avatar
Great writeup but personally I have found it a little easier to just pull the pass kick panel and just unplug the entire engine harness. Its seems to be easier to pull the harness off the motor after its out of the car to me.
Old Aug 6, 2005 | 12:00 AM
2000_LS1's Avatar
I was unpluggin it by pulling the wire connectors at the hole in the firewall. This way you don't to tear the interior out, although if you can get to it by just removing the kick panel it may easier that way.
Old Aug 6, 2005 | 12:16 AM
1QuickT-A's Avatar
I would recommend using the radiator support. Makes things a lil easier without having to worry about scratching up the nose of the car.. But, I'd rather find a lift that I can borrow!! lol
Old Aug 6, 2005 | 12:18 AM
2000_LS1's Avatar
Me too
Old Aug 6, 2005 | 12:45 AM
  #32
Originally Posted by 1QuickT-A
But, I'd rather find a lift !! lol
I just walk out in the back yard
Old Aug 6, 2005 | 01:34 AM
  #33
1QuickT-A's Avatar
I could walk out in the back yard too, but that would require a nice sized tree branch and a come-along! Thats Alabama Style!!
Old Aug 6, 2005 | 02:03 AM
  #34
2000_LS1's Avatar
Fortunately I have a shop with a lift at my grandfather's place. It's alot easier to it all, oil changes, headers, you name it, with a lift.
Old Sep 8, 2005 | 06:02 AM
  #35
skinnies's Avatar
Can the a/c compressor(already removed lines) and alt. stay? I've done 10 pulls on lt1's, but this is my first ls1 pull. It appears they can stay, but just wanting to double check.
Old Sep 8, 2005 | 06:48 AM
  #36
1BADAIR's Avatar
I left the a/c and lines with the car. Thats the only thing I removed from the engine
Old Sep 8, 2005 | 06:26 PM
  #37
Inspector12's Avatar
TT-TECH Veteran
Yes you can leave the A/C compressor and every other accessory if you are removing it from the bottom.
Old Sep 11, 2005 | 03:09 AM
  #38
2000_LS1's Avatar
Just hang it all on the front end, radiator support is what I used, when you get the car jacked up with the a/c loose. That's the easiest way I have found and since freon has doubled in price in the last year or so it's easier on the wallet as well and you don't have to worry about recharging, finding leaks, dying the hell out your a/c system, etc. Take some pics as you go for this thread so I can get back to it, I have been very very busy but I am starting to slow down again so maybe I'll have the time to finish it now, I need to find some pics of each step at least so i can show the areas in which everything is and all. If you would do that skinnies I would appreciate it.
Old Sep 11, 2005 | 03:15 AM
  #39
Ferocity02's Avatar
Any tips on lifting the car high enough to take out the motor without having access to a lift, or engine hoist?
Old Sep 11, 2005 | 03:51 AM
  #40
2000_LS1's Avatar
hmmm, maybe a tree and a come-along??? That's what I would try next. Go pick up a hoist, you can get one for the 2-3 hundred range I would think. What are you doing? Don't know any mechanics who may let you borrow a hoist or lift for a night? I had a friend and he found a mechanic that would let him use his lift for 50 bucks a night, it took us 2 nights, 1 to get the motor out, and 1 to get it back in. Take pics of how you do it though and let me know if I can be of any help. PM for a phone # if you need it.
Also may want to post in your "regional" forum, someone may be able to help you out, I would if I were closer but I'm sorry I am not driving hours on end to pull one of these beasts!!! sorry, lol.
