Pretty much free TB bypass mod
Old Jul 23, 2005 | 08:17 AM
Supajut's Avatar
Default Pretty much free TB bypass mod
Hey everyone, I did the bypass mod on my LS1 via rubber hose from intake water outlet to radiator, 2 clamps, and 2 zip ties. I eliminated all the factory hoses and clamps and went with one piece hose (didn't want leaks in the future). I came straight out from the intake to the radiator with the hose, then ran it along under the MAF to the other side. No clearance problems, looks a little cleaner, and was used with some extra parts I had lying around. Can use vaccuum caps on the TB on you would like, I did but one of them has already fallen off somewhere. What do you think? Was it worth mentioning?
Old Jul 23, 2005 | 03:28 PM
Cody Brooks's Avatar
what size hose did you use? I started to do something like that on my 99 but the end near the radiator is alot larger than that at the intake so a hose that would fit one end wouldn't fit the other.
Old Jul 23, 2005 | 03:42 PM
Supajut's Avatar
Hey I believe I used a 3/8" hose. I don't remember, I had the hose lying around and decided to give it ago before I ordered a bypass kit. It did fit snug on the radiator side but the hose wasn't too thick so it stretched just enough to work. Hope this helps. Justin.
Old Jul 23, 2005 | 03:52 PM
i think i tried that size but i was using fuel line hose so its a little on the thick size.
Old Jul 23, 2005 | 03:56 PM
slt200mph's Avatar
FYI..There are tech articles on this mod from a few years ago in LS1howto.com and installuniversity.com..both are good a source of info for the free mods and instrutions on how to do some other mods (cam & springs, heads, ect) you should check it out..
Old Jul 23, 2005 | 04:02 PM
mellowyellow's Avatar
The hose to use is 5/16th heater hose 2 ft. And yea this mod resurfaces every once and awhile..
Old Jul 23, 2005 | 04:11 PM
JustAnIlluzion's Avatar
good mod, and your way is better then just taking a barb adapter like those ebay kits have.
Old Jul 23, 2005 | 05:22 PM
Supajut's Avatar
Thanks for the support guys. I didn't see I writup when I was looking to do the bypass, so I figured I would post it for people like me that hadn't seen it. Thanks for not bashing this thread if it is a repeat. Justin.
Old Jul 23, 2005 | 05:38 PM
slt200mph's Avatar
Just wanted to pass those other two sorces on to you if you had not found them yet..
Old Jul 23, 2005 | 05:48 PM
Supajut's Avatar
Thanks for the help, I will check them out for future mods.
Old Aug 19, 2005 | 11:10 PM
FenixSS's Avatar
Does anyone have pics of how to do the TB Bypass the way that is described above?
Old Aug 20, 2005 | 02:38 AM
99SS-T's Avatar
Lol i did it the ULTRA cheap way. I broke off one of the fittings on the bottom of the TB, that used tp be a part of the TB heating system, and used it to spice the hose that comes off the heads and the hose that comes off the radiator. I didnt use 1 non stock part. GL
John
Old Aug 20, 2005 | 07:45 AM
slt200mph's Avatar
Check out installuniversity.com or LS1howtoo.com all that info is in there with photos
Old Aug 20, 2005 | 08:30 AM
FenixSS's Avatar
Install university has the BMR kit listed in their instructions. Just wondering if there was another step by step with pics source as the description in the first post is different than install university.
Old Aug 20, 2005 | 09:00 AM
cowboysfan's Avatar
I used one piece hose as well, put oil on radiator end then forcefully put hose on, about a year ago. so far no problems, works like a champ. just 4 info, did a before/after temp test. diff. TB is 25 deg cooler w/ mod.
fuerzaws6
Old Aug 20, 2005 | 05:55 PM
slt200mph's Avatar
I took the two pieces of different size hose that was on the TB and threw them away and ran a single piece of rubber hose from the head to the radiator...zip tied it to the upper radior hose ..had to lube up the fitting on the radiator but it works like a champ..you don't need no stinkin pictures...
Old Aug 20, 2005 | 08:48 PM
FenixSS's Avatar
See, now that's a better idea, just one damn rubber hose! LOL, I think I make things too hard sometimes, thanks.
Old Aug 20, 2005 | 10:53 PM
mostafa3k's Avatar
I used copper tubing to connect the ends... which i imagine doesn't help much because it gets scorching hot.
