Help Fast!!! Don't think I received the correct Torquer II cam!! tuning help>
Now what I read on their website, and from what I understand, the torquer II is supposed to have (232/234, .595"/.598", 112 LSA )
I'm reading the cam card and it states:
TSP Torquer II
Int Exh
Adv Dur: 283 283
Dur @ 0.50: 234 234 Lobe Sep: 113.0
Valve Lift: 0.598 0.598
Does the 113 lsa play a role in adjusting these numbers? Or should the numbers remain constant with the LSA's?
About to receive a custom tune via Predator, but need to know if I'm working with the correct info here guys.
Appreciate any help and direction you could give real quick.
Thanks!
AHHHH Boogers!!! And I'm about to have it installed next week!!
TSP where are you!!!
Anyone have a cam card of their Torquer II on a 113 lsa I could send to my tuner?
I just wanted to confirm first, as I need to make sure I provide the correct info on the correct cam to my tuner so he can work on a prog while the cam is getting installed, err, at this point reshipped.
My God... give the dude a break. I swear, you guys act like its a crime against humanity if someone posts about something in question from a sponsor..
the cam differences are minimal
yours:
IVO 5
IVC 49
EVO 51
EVC 3
TQ'er II
IVO 6
IVC 46
EVO 51
EVC 3
Those are the .050 specs of that cam.
IMO, send it back and insist on a correct grind if that is what you want.
If you install this one, then you void any responsibility on the vendor's part as you are aware this is not the advertised grind.
Scenario: SilverSmoke puts that 234 in. It doesn't perform to expectations and voila, any problem is then blamed on the cam. Torquer II is what he ordered, Torquer II is what he should get.
Who gets blamed as well? The shop that didn't provide the right cam.
So if he puts it in, he should be aware that this cam might not perform as the Torquer II (could be better or worse)
I believe that if he indeed ordered the Torquer II, then whoever sent him this one should replace it ASAP and pay for shipping.
yours:
IVO 5
IVC 49
EVO 51
EVC 3
TQ'er II
IVO 6
IVC 46
EVO 51
EVC 3
I'd run it.
This stuff is too confusing... so hopefully all will be well then...
Does this make sense?
From my experience these differences in grinds occur when original is designed with another manufacturer in mind and when ground by another with different lobes, the variables occur (meaning that these specs are the closest they could get with the lobes that they have)
I had this happen to me with a Stealth II cam from MTI.
Originaly designed for Comp lobes, ended up ground from LUNATI and was not performing as original. Ended up finding this; and cam was exchanged for an original COMP XE-R grind. What a difference.
01 NBM Z28- A4 w/3.23s, TSP Black Lid, Hooker Catback, Pacesetter Headers w/ORY, ASP Pulley, Ported Throttle Body, TSP Torq. v3(231/234) Camshaft, TCI 4400, PRC Stg 1 Heads
Texas Speed & Performance
www.texas-speed.com
(806) 866-0734
Jon
