idle sux
ill be driving along then stop in traffic, then boom it stalls or it will hunt for idle. im so sick of this. is there anything that will fix this. i had the car tuned already. when i put the AC on its worse
didn't slowhawk tune your car pdd? i doubt he'd just walk away from the car w/o an idle tune.
you've been having issues with that car ever since you put on the TEA-ported milled AFR's with that F14. sounds like you need to get TEA to trade you those heads for a set of stock 205's and some $$$ back!!!
I have modded the IAC tables to correct the conditions when the A/C is off. Takes a bunch of trial and error. Getting the main VE table in line really helped correct this also on my car with A/C on or off. But it still does hunt a tiny bit with the A/C on. Take it back to your tuner.
