Rock On
Old Jul 29, 2005 | 01:27 PM
v8robert's Avatar
Default Rock On
Have ordered AFR 205 heads + FM13 cam for LS6 upgrade. Engine sounds a bit loose, think its the rockers however there is no performance loss. Would it be a good idea to get a stronger than stock rocker set now or watch and wait ?
If so what set would you recommend ?
Cheers for the advice in advance
Rob
Old Jul 29, 2005 | 03:26 PM
Tony Mamo @ AFR's Avatar
Flow Wizard
Rob
Did you check pushrod length?
If so, what is the preload on your lifters set at?
My guess is you need a slightly longer pushrod....
Old Jul 29, 2005 | 04:42 PM
v8robert's Avatar
Its totally stock at present so god knows. I have hardened pushrods coming with cam and head upgrade so might not be an issue after installation
Cheers
Rob
