AFR heads installed
Old Jul 31, 2005 | 07:11 PM
smask04C5's Avatar
Default AFR heads installed
update, removed PP heads yesterday, checked installed height on AFR's both heads were at 1.78 with crane springs and retainers. installed crane springs and prepped for install today. started assembly after noon today, sprayed .040 cometics with permatex copper, torqued studs to 70 with moly. adjusted 1.8 crane rockers as per VHP instructions, amazingly quiet valvetrain. used 7.325 p/rods on AFR's milled .024. Appears to be decent geometry. brought engine to operating temp and varied the idle speed on jackstands, then changed the oil. will post up once i get the #'s from this baby cam. Thanks again tony, hats off to AFR, quality products.
Old Jul 31, 2005 | 07:16 PM
gomer's Avatar
You say "baby cam" but you didn't give us any specs???
Old Jul 31, 2005 | 07:42 PM
smask04C5's Avatar
gomer i am running the vhp 056 216/224 .551 lift 115 lsa. using crane 1.8 rockers, about .590. tony is interested in how the combo works.
Old Jul 31, 2005 | 07:55 PM
1QuickT-A's Avatar
Baby cam is right!! that thing is TINY!!
Old Jul 31, 2005 | 08:00 PM
smask04C5's Avatar
ran previous heads for 2000 miles, think I will keep these on for a while,getting too old to do this kind of work
Old Jul 31, 2005 | 08:36 PM
1QuickT-A's Avatar
I heard that! Did you ever get it dyno'd with the other PP heads??
Old Jul 31, 2005 | 08:53 PM
smask04C5's Avatar
yes, have graphs in file somewhere, high 380's as I recall
Old Jul 31, 2005 | 09:04 PM
1QuickT-A's Avatar
380's! ewwwww
Old Jul 31, 2005 | 09:56 PM
ROCNDAV's Avatar
This is the first that I've heard of anyone doing this. I thought cometics were supposed to be applied dry?
Old Aug 1, 2005 | 12:09 AM
Tony Mamo @ AFR's Avatar
Flow Wizard
They are.....
I'm thinking if it would have caused some issues he would have found out already....LOL
Hopefully the AFR's help you clear the 400 mark....Looking forward to the results. Also, seeing as you will have driven the car with both heads Im curious about your input regarding low speed drivability, throttle response, etc.
Keep us posted....Good luck
Old Aug 1, 2005 | 12:14 AM
1QuickT-A's Avatar
I've only used copper sealant on 100% copper gaskets.. I'm sure it will be ok tho..
Old Aug 1, 2005 | 03:04 AM
98Grnz28's Avatar
That cam is tiny.
Old Aug 1, 2005 | 10:37 AM
1QuickT-A's Avatar
thats the "itty bitty titty comittee" cam
