? On heads Need Help ASAP !!!
Old Aug 3, 2005 | 07:56 PM
khris99s's Avatar
Default ? On heads Need Help ASAP !!!
Have 98 A4 with 226/585/112 Cam Need to know if Milled .03 Heads will be a problem AS FAR AS CLEARANCE ISSUES ? Any help appreciated. Purchasing heads tonight need to know.
Old Aug 3, 2005 | 08:11 PM
FiveSevenEagle's Avatar
if u still running the 98 engine then u should know that ur heads bolts r different than the 99+ ... they r perimeter bolts , 99+ have a center bolt type , check jrp`s super FAQ for the pix and the differences ,
dont worry u can fit the center-bolt type heads , u need to change the valve cover and some other NO BIG DEAL things ,
this is all what i know ,
Old Aug 3, 2005 | 08:12 PM
smask04C5's Avatar
should always confirm p/v with clay, only way to be sure. are they stock diameter 2.00 intakes?
Old Aug 3, 2005 | 08:20 PM
khris99s's Avatar
Default I understand the difference.
These are off a 98 So they will fit no problem. I am just wondering with the cam I have and them beingmilled will I have clearance issues. Yes they are stock valves, Ported Polished Milled .03
Old Aug 3, 2005 | 08:21 PM
u need valve cover ( get them from a salvage yard ) and coil pack brackets that mount on top of the center bolt style covers.
as long as i know these r the things u need if u r using a perimeter type bolts and u want to go with a center bolt type heads .
maybe u need to flycut the pistons maybe not .. how would u know ? as smask04C5 said u need to confirm piston to valve clearance using the clay method .
