Bottom end girdle
Do you know what I am talking about? The crank cover on the bottom of the motor found above the oilpan.
Am I calling that that wrong thing??
ify ou are using a LS1 oil pan, i believe you have to change the windage tray, I know you can use it, im not sure on the 4" crank though. I believe usually spacers are used however im not 100% on that.
thanks
ed
There was a cover on the bottom end, bolted onto the main caps. The oil pick up was also bolted on it. Looks like it would come close to the crank....should I just fit it on the new motor and see?? What would enough clearance be?
