Bored out ls1?!?!?!?
Old Aug 8, 2005 | 11:28 AM
MonsterZ28's Avatar
Default Bored out ls1?!?!?!?
Ive heard that there is a way to get the ls1 engine bored out so it has about 600hp, does any one know if this is true and if so where to get it done? I do remember seeing a yellow SS on the cover of a year one parts book with the 600hp tag on the side of the scoop.
Old Aug 8, 2005 | 11:44 AM
conan's Avatar
You can get the block bored and resleved to a 427 and alittle biger, and probly see 600fwhp but get your check book out.
http://www.motorsporttech.com/fbody_engine02.asp
Old Aug 8, 2005 | 11:50 AM
BOONE's Avatar
Boring the ls1 is not going to net 600 hp ever. There is alot of money to spend achieving 600 hp, no short cut anywhere. My suggestion is to read and read and read this forum and store up some knowledge and make some educated decisions when you are ready but save in the mean time for your dreams. If you have the money already id study up and decide what direction you want to go. A stroker 427 NA may be what you want or N2o or maybe a turbo????? Hp will cost alot eventually even with N20. N20 might be the shortcut you are looking for price wise??
Old Aug 8, 2005 | 12:38 PM
ROCNDAV's Avatar
Doesn't the Dick Harrell Berger Supercar put out 630 HP? that what the cover of the magazine read. Then again, that was a 427 C5R block
D
Old Aug 8, 2005 | 12:58 PM
777's Avatar
777
You could do it with the right combo. BTW you can't really bore an ls1. You can either re-sleeve it or get a different block (lq9, ls2, c5-r) Ls1's will only take a slight hone up to ~348. Typical is a 347 though.
Old Aug 8, 2005 | 01:00 PM
777's Avatar
777
D
Just because it has a c5-r block doesn't mean it will make more power. You can re-sleeve an ls1 to a 427 and make the same or close to the same power. The c5-r just adds strength and durability. Which is not really a factor at 600rwhp N/A.
Old Aug 8, 2005 | 01:34 PM
MonsterZ28's Avatar
wouldnt it b cheaper to jus buy the new ls7 crate motor instead
Old Aug 8, 2005 | 01:42 PM
ROCNDAV's Avatar
I don't know about cheaper, what do they cost?
The costs of moving up are not just the block itself, but beefing up everything else to deal with the added torque/power.
Old Aug 8, 2005 | 01:44 PM
PREDATOR-Z's Avatar
C5R block means no sleeves. C5R block, heads and sheetmetal intake with a nasty cam WILL make 600rwhp. Oh and Custom headers too, EWP, 90 TB, high SCR, 600 is prolly a little conservative. But can you say 60>75K for that motor?
Old Aug 8, 2005 | 01:46 PM
777's Avatar
777
Ls7 crate motor's are going to be big $$$. They have ti-rods and forged internals so there isn't much beefing up you can do to them. They have INCREDIBLE heads that are near c5-r level. Not to mention it's just a straight monster of a motor.
Old Aug 8, 2005 | 01:49 PM
777's Avatar
777
I am lost. I don't recall saying anything that would disagree with what you just said. I know c5-r blocks have no sleeves (well they are built in from the factory). I know a c5-r block, heads, and sheetmetal intake with big cam will make 600rwhp. So will a darton sleeved 427 ls1 with c5-r heads, sheetmetal intake and a nasty cam. (along with all the nice bolt-ons of course)
Old Aug 8, 2005 | 01:56 PM
PREDATOR-Z's Avatar
I know, I was just adding to it
Old Aug 8, 2005 | 02:07 PM
JakeFusion's Avatar
Super Hulk Smash
I think the LS7 crate will cost about $12-14k depending on where you buy it from, unless demand outweighs supply, and then we = raped on price.
Old Aug 8, 2005 | 02:10 PM
777's Avatar
777
gotcha
Old Aug 8, 2005 | 04:16 PM
BLK UUS-6's Avatar
Sorta just adding to the post, but i have an ls6 motor that needs some machine work. What is the deal with these things, i have people sayin 20 over is ok, some say 30 is max and some say 10 is it. What are your opinions?
Old Aug 8, 2005 | 04:26 PM
slt200mph's Avatar
D
Those cars and the other Camaro speciality cars that GMMG builds that are 427 cu. in. use the C5R block nothing cheep about that setup...they will custom build you a car to your specs...they rock and roll but bring plenty of $$$..
Old Aug 8, 2005 | 04:38 PM
strokedls1's Avatar
About a .005 hone is all you want to do max. If they are telling you it can go .020-.030 they don't have a clue about ls1 motors. The sleeves are too thin for anything but a clean up hone.
Old Aug 8, 2005 | 04:43 PM
ROCNDAV's Avatar
97-00 LS1 blocks allow for a .004" clean up hone. 01+ LS1 blocks allow for a .010" bore. I believe (but not 100% positive) that the LS6 blocks are the same.
Check JRPs sig for more info.
David
Old Aug 9, 2005 | 11:59 AM
WANARUNM's Avatar
Had mine done 30 over 2 months ago, so far so good no dyno numbers yet but i gaurantee you that its no where near 600 hp!!
Old Aug 9, 2005 | 12:10 PM
ROCNDAV's Avatar
yeah, I also went over the suggested / allowable after chatting with a few others that have. We didn't go .030" over like you did, just enough to get my 3.905 pistons in there. I haven't spoke to anyone with 4000+ miles yet. but most haven't had problems.
