Stock Rocker HELP!
Old Aug 9, 2005 | 01:43 PM
ashade98's Avatar
Default Stock Rocker HELP!
I just got some used stock rockers in the mail that I'd ordered from someone on the forum. I noticed that the rockers are stamped A2, E2, I5, K4, F7, H5, G6...etc. There are a few with duplicte stamping. Is this right? Are these a set? This is the first set of stockers I've had lying in front of me, just can't make any sense of the stamps, there is no rhyme or reason (order) to them. Please let me know what you think.
Attached Thumbnails Stock Rocker HELP!-100_0387-1.jpg   Stock Rocker HELP!-100_0388-1.jpg   Stock Rocker HELP!-100_0386-1.jpg   Stock Rocker HELP!-100_0389-1.jpg
Old Aug 9, 2005 | 01:45 PM
Krab's Avatar
Can you post a pic of them?
Old Aug 9, 2005 | 01:55 PM
Redneck Z's Avatar
What a tripper, just throw em in. Don't ask questions.
Old Aug 9, 2005 | 02:06 PM
Krab's Avatar
http://ls1howto.com/index.php?article=21
Click on the link and look at the first set of pics comparing the YT rockers and stockers. If the rocker you have look like the smaller ones, then they are indeed stock rockers. It doesn't really matter in what order you put them in so I don't know about them being stamped. Like Redneck Z said, just throw them in!
Old Aug 9, 2005 | 02:11 PM
ashade98's Avatar
Check the pics! Seems a little weird. They deffinatley seem like stockers, but whats up with the Letters and #'s? Almost all different?
Old Aug 9, 2005 | 02:27 PM
vettenuts's Avatar
Different casting lots maybe?
Old Aug 9, 2005 | 02:47 PM
fugasi's Avatar
I just took my stock rockers off last week and noticed the same thing. I don't believe they go in any particular order, but just do a bit more research before you throw them in. Maybe call a dealership or local shop that knows LS1s. Best guess is as vettenuts said, different casting batches, same rocker.
Old Aug 9, 2005 | 03:35 PM
ashade98's Avatar
Just talked to Sean (a.k.a valvegod) at SMC. I was ordering some valve covers..... So I asked the guru about the rockers, he said that it is completely normal. They're always like that... dunno why??? Oh well.. good enough for me.
Old Aug 9, 2005 | 04:59 PM
Redneck Z's Avatar
Now that you've got the LS6 intake and rockers, when are the heads and cam gonna arrive?
Old Aug 9, 2005 | 06:18 PM
ashade98's Avatar
veddy soon laddie! not sure which address to have 'em sent to???
Old Aug 9, 2005 | 06:33 PM
Demon SS's Avatar
the numbers and letters signify which which mold was used to cast them. they use this to keep track of any that may have a fault to see if it is a common mold problem or an over all problem. has nothing to do with the order that they go in. basically the same thing as the clock that you see stamped on alot of things.
P.S. i suck at english today
Old Aug 9, 2005 | 08:08 PM
ashade98's Avatar
thanks for the response!!
