Comp LSK Lobes
Old Aug 10, 2005 | 10:03 AM
Phil99vette's Avatar
7 Second Club
Default Comp LSK Lobes
Has anyone used these? I recieved a fax from comp cams about these new lobes and they sure have some lift!
Phil
Old Aug 10, 2005 | 10:25 AM
Ragtop 99's Avatar
can you post the lifts or a comparison to the X-er lobes? Maybe at 224, 232, 240 durations so we can get a flavor of how they compare.
Old Aug 10, 2005 | 10:28 AM
7 Second Club
Dur: 1.7-1.75-1.85
223 .636 .655 .692
231 .643 .662 .699
239 .649 .669 .707
247 .656 .676 .714
Old Aug 10, 2005 | 11:02 AM
gtovan's Avatar
I'm running the LSK 243 duration lobes on a single pattern .653 lift w/ PRC duals and Morel lifters. Has .200" duration numbers close to XE-R 248 lobe, so it ramps aggressively after .050. They are about as close to solid roller performance w/ a hydraulic setup that I could find. I don't expect a lot of mileage out of the springs (10-15K?) but I like the way it hits and PRC's are not that expensive.
Old Aug 10, 2005 | 11:06 AM
Patrick G's Avatar
LS1 Tech Administrator
I've got them on the intake of my TRak cam! Revs like a ****!
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old Aug 10, 2005 | 11:17 AM
gtovan's Avatar
Here are the specs on the whole series:
Comp Cams LSK lobes
Lobe#, Dur. @ .006", .050", .200", & Lift w/1.7 rocker
2124 265 215 142 .629"
2125 269 219 145 .632"
2126 273 223 149 .636"
2127 277 227 153 .639"
2128 281 231 156 .643"
2129 285 235 160 .646"
2130 289 239 164 .649"
2131 293 243 168 .653"
2132 297 247 171 .656"
2133 301 251 175 .660"
2134 305 255 179 .663"
2135 309 259 183 .663"
2136 313 263 186 .663"
Old Aug 11, 2005 | 09:33 AM
7 Second Club
They will custom grind anything you need...
Old Aug 11, 2005 | 09:51 AM
gomer's Avatar
I've been thinking about doing a 215/219 .629/.632 115+0 with a set of PRC 5.3 heads on my wife's car. I wonder how good it would idle and if it would be ok on P/V with the 5.3 heads unmilled??
Old Aug 11, 2005 | 10:58 AM
PREDATOR-Z's Avatar
Use the "Dial" Gomer
Old Aug 11, 2005 | 11:01 AM
7 Second Club
What springs would you use on a .650" lift cam???
Phil
Old Aug 11, 2005 | 11:04 AM
Ben R's Avatar
Lift doesn't affect PTV. Duration and LSA do. That cam would clear no problem.
Old Aug 11, 2005 | 11:08 AM
LOnSLO's Avatar
LSK lobes are radical. They are designed to be "done" by 6500rpm max. In other words, they are some valve floatin *****.
Old Aug 11, 2005 | 11:11 AM
PREDATOR-Z's Avatar
Phil
PRC "Platinum" .670 lifts.
Old Aug 11, 2005 | 11:24 AM
gomer's Avatar
I think I may order one and try it out. The car has all bolt ons, 100hp dry kit, and a 3400 stall with 3.23 gears.
Old Aug 11, 2005 | 11:33 AM
Patrick G's Avatar
That statement is absolutely FALSE. The LSK lobes were designed by Comp to have more high rpm stability than XE or XE-R lobes.
XE-R lobes are 49 degrees from .006" to .050". That's fast.
LSK lobes are 50 degrees from .006" to .050. Not quite as fast.
Where the LSK lobes shine is the arc they form from .050" to peak lift. According to Comp, the LSK lobes better follow the natural arc of the cam. See, fast ramps and low lift (like an XE-R lobe) make the lifter want to "loft" off of the cam lobe. By adding more lift into the lobe design, Comp feels they can get more stable rpm ability.
My new Thunder Racing TRak Cam uses the 231 LSK lobe on the intake and it revs to the freakin' moon. I need to raise my rev limiter ASAP because the 6800 rpm redline feels like 6000. It would go 7500 no problem. For rev assurance, I'm running Comp 921 springs, but I could have shimmed my duals that came with my AFR 205s and been fine.
__________________
Old Aug 11, 2005 | 11:37 AM
SideStep's Avatar
This thread got some quick post.....
Patrick G's Avatar
Well then Gordon and his engineers at Comp are wrong, and so is a certain engine testing facility, seeing as I was told the exact same thing by both parties.
What testing would that be?
Old Aug 11, 2005 | 11:39 AM
Ben R's Avatar
Originally Posted by Brian@CompCams
Yes it does. If you kept the same duration and LSA, then keep adding lift...sooner or later it will hit.
Somehow I knew you'd make it in here. LOL.
This is true but at those durations it would take a bunch of lift to run into PTV problems. Especially with that LSA. Or if you put it in super advanced or retarded.
Old Aug 11, 2005 | 12:11 PM
PREDATOR-Z's Avatar
That has the same rate as Cam Motion intake lobes on some FM cams I've seen.
Old Aug 11, 2005 | 12:16 PM
LOnSLO's Avatar
I may just have to sit on the sideline on some of this discussion.
Well can you shed some light on these new lobes?
