multiple misfire problem!!!
So I check fuel pressure and a volume test and it's good, I pull injector#2 & 4
and they're both clean and have good resistance, and swap them anyways, and cyl 4 is still the worst. vacuum is good and steady, I tried to reset the pcm by disconnecting - terminal, and still I haven't found anything and I am still getting multiple misfires, however the ses light is not blinking
Please let me know if there is anyelse I could check to see that is messed up, If anything I am trying to find an ls1 specialist around nyc that will be able to help me out here, the car was done by vette doctors, so I was thinking of going back to them but just wanted to search around before I did anything
I also put stock maf in and it made no difference
the car has a thunder racing 224/224 cam, kooks lt headers and y pipe with high flow cats,ram air kit and cai, borla exhaust, granetelli maf, ported throttle body, ls6 intake manifold
