Ported head question?????
Old Aug 11, 2005 | 06:43 PM
1ORANGEWS6's Avatar
Default Ported head question?????
When intalling ported heads should you use silicone on the rocker arm bolts to keep any oil and air from leaking into the cylinders? I used loctite when I put the rocker arms on. A friend of mine told me that I needed the silicone as well.
Old Aug 11, 2005 | 06:53 PM
Redneck Z's Avatar
Yeah, on every other one. I used silicon on the ones that you can feel inside of the intake ports.
Old Aug 11, 2005 | 06:56 PM
smask04C5's Avatar
use loctite 545 thread sealer on the bolts and torque to 22 ft.#'s
Old Aug 11, 2005 | 06:58 PM
99ssleeper's Avatar
Would ARP thread sealer work too?
Old Aug 11, 2005 | 07:18 PM
smask04C5's Avatar
Yes, it would be fine, some use thread sealer with 271 loctite on head end of bolt, but really not necessary if properly torqued.
Old Aug 11, 2005 | 07:23 PM
smask04C5's Avatar
AFR 205 heads I just installed on my vette, crane studs don't protrude into the intake runners.
