help with starter
Old Aug 11, 2005 | 11:55 PM
yak's Avatar
yak
Default help with starter
can someone tell me where the bolts for the starter on on a 98 A4?
Old Aug 12, 2005 | 09:34 AM
LS1FIRE's Avatar
On the passenger side of the car you will notice the transmisson connecting to the engine. you will see a black shield made out of plastic being held on by one 10mm bolt. Look directly about it there should be the starter and you will see two 15mm bolts one shorter then the other.
Old Aug 12, 2005 | 11:50 AM
98z28chevy's Avatar
Yeah follow his advice u should find them also the bolts are a golden color on mines not normal gray color. Also i picked up a start from autozone i had to go to GM and get a longer bolt the starter needs 2 long bolts instead of 1 short and 1 long.
Old Aug 12, 2005 | 03:30 PM
yak's Avatar
yak
thanks guys, I never needed to drop my starter. I held the pulley from spinning while my buddy cranked on the puller. came right off. today has been good. the pulley came off and the ups man brought me this box with a big bumpy stick in it.
Old Aug 13, 2005 | 04:33 AM
98A4LS1's Avatar
puller?
Old Aug 13, 2005 | 10:08 PM
98z28chevy's Avatar
Where u talking about Harmonic Balancer? the round thing below the water pump?
Old Aug 13, 2005 | 10:11 PM
SSEUL8R's Avatar
Some people should NOT work on their own vehicles...
