How deep to flycut?
Old Aug 12, 2005 | 10:51 PM
bigdsz's Avatar
Default How deep to flycut?
How deep to flycut? AFR heads milled .034,I think the CC's are now 59 cc. Cam is Comp XER lobes 242/248 .610/.615 111lsa. How deep shoud I fly cut the first go round before I put on a dial indicator and clay the chambers? Starting tomorrow need to know ASAP. Thanks
Old Aug 12, 2005 | 11:36 PM
JF WS6's Avatar
Since you're planning on claying it, I'd just clay it first with no cuts (make sure you use a solid lifter or a shimmed stock lifter so that the plunger doesn't go down in the lifter) see what your clearance is, then take that into account with what you'd need to cut to have around .080 total clearance. Follow the flycutting procedure from the Forcefed hp home page and use feeler gauges to set up the depth on the collar of the Isky tool and once it's set you should be good to go for the rest of the cylinders.
http://www.forcefedhighperformance.com/tech_Isky.htm
Old Aug 14, 2005 | 08:43 AM
as35thss's Avatar
To the top.
