Experts inside!
Old Aug 18, 2005 | 11:18 AM
LASTLS1's Avatar
6 Second Club Moderator
Default Experts inside!
Missing RPM! I'll make it as short as possible. LME 408 iron. 13.5 to 1. FMS cam 275-286 .735-.715 @112. Jesel shaft mount rockers. Solid roller. Rpm peaks at 6200????? It should peak around 7500! Torque peaks about 5500. Dropped the exhaust on the dyno and lost hp? A/F and timing doesn't help. Fast intake 90/90. I tried three different MAFs. LS6 heads.they flow 323 from .650 to .750 Intake valve is a 2.10. Heads are not great by any means, BUT stock heads with small valves should be able to run higher rpm than 6200? I'm lost.
Old Aug 18, 2005 | 11:43 AM
Patrick G's Avatar
LS1 Tech Administrator
The intake manifold runner length is going to force your motor into peaking lower than you want plain and simple. If you run a sheet metal intake with runner length optimized for your rpm window, I'm sure you would make peak power at a much higher rpm level.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old Aug 18, 2005 | 12:00 PM
LASTLS1's Avatar
I agree that the intake isn't the best for high rpm but the same intake ran to 6700 with a hyd roller much smaller cam 242-250 .611-.619 @ 113.???? This is driving me nuts!
Old Aug 18, 2005 | 11:44 PM
LASTLS1's Avatar
No thoughts??
