[Q] temp always stays below 175
(driver side, engine block sensor),
flashed the old coolant out, put new dexcool compatible 50/50
prestone 150K miles/5year coolant, added 1.5 bottles of waterwater
and since then my gauge never shows over 175 engine temperature.
Now I bought also a laser temperature meter, and measuring the
temperature I get
172 degrees by the coolant temperature sensor (driver side, engine block)
about 138 on the MAF airflowcensor
about 190 on the headers themselves
my gauge shows 173-175 even after leaving the car running still
for 15 minutes.
so my question is, is my new coolant temp. sensor faulty (I got
it from a dealer ship for 28$)
or is my car really running that cool
(south FL, very humid, very hot)
'98 LS1 formula (hookers headers/exaust, SLP mass airflow censor,
LS1 ram air lid,160 thermostat, tuned with HP tuner software )
thanks in advance
to see what it will do (AC was on)
my fans are now set to come on at lower temperatures now (I have the 160 thermostat, and just a week ago set it to be lower, but the temp stayed low
even before that)
probably the new coolant temperature sensor is faulty... should it show the temperature on the engine block or the headers? (it is measure the coolant temp,
but I do not know if there is any internal adjustment...)
Also when i was tuning my car with HP tuners the guy said that the computer
was reading about 182 when my gage was showing 175-179... so where would the
computer be getting that reading from?
thanks
but still. The gauge shows 175 or so, while Engine block is around 198
Do you guys know what sensor exactly is responsible for the temp gauge?
Thanks
