What heads work well on a 402?
Thanks guys
What will the car see as in drivability? Is it a daily driver? Weekend warrior? Etc.
The cam depends on PtoV clearance, how much dish or valve relief is in the piston, the size/flow of the heads, etc.
Not everyone's "best combo" is the same. Everything is different for every person and their goals for their car.
Thanks for the help 1QTA.
the 24x range isnt that big, and you can definatly go bigger. Its actually pretty tame...
Solid roller will be your friend for max effort.
1quick, point me to some threads with big powered 225 setups please. I'm not seeing how you are getting the compression with such a large CC chamber. You'd have to run a flattop with alot of relief to run any sizable cam.
If you are using it to get Kentucky fried rat at the local drive-in consider a smaller cam that will idle and run on pump gas.
Need a cam with a large amount of overlap to cover up the smell...
Or just have it idle really rich
j/k
BTW this is not a solid roller cam
If I get in the mood for some original recipe rat, I'll park it...but I probably wont be using it for munchie runs.
What do I give up with a solid roller? More maintenance? Whats the maintenance like on a solid roller? What is the benefit to going with a solid roller?
And lastly, is it worth the extra money for an LS2 block? How much weight do you gain with an LQ9? The iron block is better if I decide to spray in the future?
DestroyerSS...gimme a PM when your motor is done. I'm interested in seeing how it performs
Thanks guys
Check post #3, #6, #25, #30... Those are just a few of PLENTY..
https://ls1tech.com/forums/showthrea...th+AFR+225%27s
Theres another.. 500+ with out of the box AFR's thru cats..
72ccs with a .040 cometic, pistons .010 outa the hole, with a 2cc valve relief is 11.4ish
Still dont think its the IDEAL setup for a wild N/A combo.
Well what exactly would you recommend without spending a ton of money?? Most of the guys on this board are not going for "wild".. But, 550rwhp with a set of out of the box heads is pretty damn impressive where I come from and that is more than enough for most people.
